Old 12-14-2015, 10:14 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
From an engine builder's standpoint, your carb tune will play the biggest role in how long your engine lasts.
Back in the 60's-70's when carburetors were still the primo way of fuel delivery, you couldn't expect an engine to last more than 40-50k miles. Anytime the choke is on, or anytime the A/F mixture is rich, it will wreak havoc on the condition of the cylinder walls. Fuel injected engines, on the other hand, will generally last much, much longer.
Gotta keep an eye on your fuel pressure (too high of fuel pressure can cause issues, most carbs like 5-6 psi) and gotta keep an eye on the idle A/F ratio, as well as the A/F ratio at WOT. Remember, different pump gas formulations can cause problems, even something like changing an air cleaner can disturb the A/F ratio. Excessive amounts of fuel will wash the oil off the cylinder walls.
Otherwise, the other guys listed some very good things to watch out for. Also, generally speaking, the more radical the engine, the shorter the life expectancy, due to higher cam lift, parts flexing due to high horsepower, etc, etc.
Well that sucks to hear. I was just getting comfortable with the fact of accepting keeping the carb on the car! What is the ideal A/F during idle and can you achieve an ideal A/F ratio at idle when your have a more radical camshaft? When I pull my motor for the cam swap what is the recommended way to check for ring wear?
