Old 12-15-2015, 07:26 AM
bjretired's Avatar
bjretired bjretired is offline
Cobra Make, Engine: Antique Collectable, Chevy BB
Originally Posted by PNJSNAK View Post
H-rod
The rad mount is correct, not sure why it was designed that way, but I just mounted it.
I also did not use the self tapping screws. I drilled thru and mounted with bolts and nuts.
I had seat tracks bolted thru the fiberglass with large washers.
I went with new seats after a while because of no support or cushion in A$C seats and I mounted them right to the floor so no adjustment.
The glass floor is about 1/4 to 3/8" thick.
Maybe others will chime in from A$C forum
Jim
Yes the floors are very thick. You would never pull through the fiberglass floor. 3" washers
Pics americantorque.com/bj
