Old 12-20-2015, 06:05 AM
rhunt rhunt is offline
Cobra Make, Engine: FFR, Windsor based 427, naturally aspirated, 770 cfm Holley
Default Hot Running Windsor based 427 FFR Roadster
Mikeinatlanta, thanks. Agreed on the thermostat and velocity of water through the radiator. It is not the thermostat or in my testing cases the lack thereof. There has been no change in the max. water and oil temperatures with three different or no thermostat conditions. In fact I am now an expert on replacing Ford thermostats I've done it so many times. Water pump for the record is correct from Ford Racing for this engine. Although I have put an overdrive pulley on it to turn it faster. Thought I might be cavitating the pump by doing this with no thermostat installed as the pump is centrifugal and operating well out on its curve. Those were my thoughts. This engine ran on the Ford engine dyno without the high temps and put out 537 hp. Will check timing again and some of the other suggestions and then advise all. Inline filler is high on the outlet hose between block and radiator inlet. Have burped this thing more times than I like to count. I do lose a small mount of fluid into the overfill tank after each test run on the car. So I top it off.
