Old 12-20-2015, 06:42 AM
gunkk's Avatar
gunkk gunkk is offline
Pallet required. A layer of 3/4 plywood under the block and metal straps or hold-down bolts strongly recommended. Even for a one off shipment, most LTL (Less Than truckLoad) will give you a 70-80% discount off published rates. They will top stack so make sure your crate has 2x4 supports. Ask for a NMFC class 50 or lower rate.
motorhead finally found his motor
