Old 12-20-2015, 08:21 AM
mikeinatlanta mikeinatlanta is offline
Originally Posted by cycleguy55 View Post
Why are you concerned about 210°F? That's well within normal range and far from overheating or boiling over - unless you're running straight water with no pressure cap.
As others have pointed out, the 160°F thermostat is too low, and a 180° or 190° would be much better. As you have noted, it made no difference on your temperatures.
Check out the tech tips on pages 21-23 of this: https://stewartcomponents.com/wp/wp-...rt_catalog.pdf
Interesting article. I haven't head of the water pressure overcoming the radiator cap at high rpm but the possibility seems logical. If I end up with that issue I'll switch to a very high pressure cap at the tstat and go with a surge tank. They basically say the same thing I was in regards to coolant flow through the heat exchange and the need for a stable air pocket for air removal.
