Old 12-20-2015, 10:16 AM
ACademic ACademic is offline
Originally Posted by rhunt View Post
50/50 water glycol with 2 cans of H2O Wetter. Ambient temps now 65 deg F in TX, water temp hits 210 deg F & oil temps hits 215-200 deg. Laser shot of radiator show about 180 deg F. All air burped out of system.
You running mechanical or electric gauges? Mechanical senders can get finicky. Oil temps in general should run approx. 20* hotter. Two bottles of WaterWetter is probably 1.5 too much. Have had great success with WW...good product. If you are using a surge tank you should only fill it half way, otherwise you don't give air pockets anywhere to go. As for thermostats, if they were not necessary than every OEM would have ditched them decades ago and saved boxcar loads of money. Water pumps shouldn't have to be overdriven to work properly. Make sure the puller fan is properly sized and shrouded. My two cents.
