Old 12-21-2015, 12:46 PM
Ace23 Ace23 is offline
Cobra Make, Engine: SPF#1867 , KC427
Originally Posted by madmaxx View Post
It is possible to change the cam with engine in the car. You have to remove the radiator fans. You disconnect motor mounts and jack engine up and swing engine to driver side to clear the front cross bar and the cam comes out in the fan opening.
Interesting. I will see what Pman wants to do since it is his garage. I know he has pulled his motor a few times changing engine combos. I'm pretty excited about the new cam from Brent. He went with a 108LSA and brought the peak power down to 6000rpm from 6600rpm. Should be a good compromise to what I have now.
