Old 12-21-2015, 08:12 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Cam change is not the only modifications or improvements Ace23 has planned for the car. Polished Intake, polished water pump, quick-time bell housing, rear main seal, change AN fittings to a clear or black finish, etc. Yes, I would assume taking out some components such as the radiator and lifting the motor the cam swap is a possibility, However, by removing or disconnecting a few more items we can lift the motor out, put on a stand and swap parts without breaking our backs. Setting valves, degreeing the cam and checking bellhousing alignment all will be easier as well. Most of all Ace23 can finish detailing the engine compartment! Wax on wax off.....
