Old 12-27-2015, 05:23 AM
Cobra Chris's Avatar
Cobra Chris Cobra Chris is offline
Cobra Make, Engine: FFR
He did more of a modern hot rod version along the lines of what a lot of you guys like. He did a piece of vinyl over the FIA bump with about a 1" border. The border had the rivet head holes cut out and a surrounding layer over the bulkhead cut right up flush to the borders edge. This effectively made everything level with each other for a top layer to sit very flat over it. I have some pics of it somewhere if my description isn't clear enough Ron. Keep up the good work and great detailing! Since you're in the rivet counters ranks it's 9 rivets top and bottom and two on each end ;-)
So the rivets are visible? Nick, I would appreciate if you could post those pics if possible...
Thanks!
