Old 01-01-2016, 09:05 PM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
Originally Posted by CHANMADD View Post
The right way ......is a spacer ....specifically made .....Bellhousing adapter to put a'84-'92 S10 T5 onto a 1955 & up Chev bellhousing
If you just cut the tip of the input.......it will not sit in the pilot bearing ,and the clutch plate will not properly engaged in the splines....that's why it sticks......
"If you just cut the tip of the input.......it will not sit in the pilot bearing ,and the clutch plate will not properly engaged in the splines....that's why it sticks......" Yep, that's what I experienced.
A spacer is an option but its quite simple to swap the input shaft and bearing retainer, much cheaper than buying a spacer.
