Old 01-03-2016, 03:06 AM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Originally Posted by Jaydee View Post
Is it possible to use a direct cable to the butterfly? I don't really like drive by wire throttle. Sometimes throttle response is slow.
JD
I don't believe so. The ECU/PCM uses throttle position,the signals from which it receives electronically from the pedal. There are quite a few wires in the accelerator pedal loom as well so I'd proffer that it's fairly well entrenched.
www.paintwerks.com.au
