Old 01-05-2016, 10:05 AM
Cobrat24's Avatar
Cobrat24 Cobrat24 is offline
[quote=eschaider;1376906]There is a reason that supercharged race cars run in different classes than n/a cars and it is not because the n/a cars make more power.
If you are funds limited then you should either set your sights lower (maybe accept lower power right now) and save until you can afford to build the bigger engine correctly.
Trying to make a beast of burden on a budget run like a purpose built high performance engine is a waste of your money and time. It will only increase the cost of what you want by the dollars you spend on the engine you didn't want.
Decide what you want, what it will cost and begin saving and buying parts as they present themselves to you. When you are done putting perfume on a pig it is still a pig. Budget, save, buy, build and then enjoy.
Ed[/QUOTE
Thanks Ed. I appreciate your advice man.
I plan on doing something one way or another, the cobra is too slow. So if it's slapping on heads , cam , intake and better exhaust for 450hp on the 302, although that won't be rear wheel it's better than what I have now by at least a 100hp.
