A factory high-torque gear reduction starter was used on '92-'96 E-series w/460; and 92-97 F-series w/ 460. While most of these were for automatics, they will work on manuals as well. Only difference is the nose; the manual trans starters had a slightly shorter nose cone. Added plus is the late model case is quite a bit smaller and the unit lighter. Worked like a champ in my old car. If your parts house is too high, check these guys:
[ame="http://www.amazon.com/DB-Electrical-SFD0030-Starter-Mercury/dp/B00KGIEDZY"]Amazon.com: DB Electrical SFD0030 Mini Starter (Ford Truck Van Mercury 460 engine 3226): Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/51ntgzM2XZL.@@AMEPARAM@@51ntgzM2XZL[/ame]
I bought one from them and it was quite good in performance & price. You should also run a ground from a starter bolt to frame to get max performance.
Good luck!!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
