Old 05-06-2002, 09:52 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
What manufacturer cobra do you have? You can probubly send your header out to a good custom header manufacturer as samples and have new ones made in whatever size you need. I strongly recommend Doug's Headers in anaheim ca. Your engine builder should recommend the header diameter.(350 cid, 6000 rpm 1 5/8 : 400 cid, 7500 rpm 1 3/4)The sidepipe primaries should be larger, as they are asthetic as well and what's another 10 hp?
