Old 01-24-2016, 09:30 AM
Dusty Mills Dusty Mills is offline
Registered User
I have the crimestopper seat heaters. When I worked at a dealership I installed a few and never had a comeback or complaint.
If you want the switches up front you'll have to extend the harness, I usually use a stinger 9wire cable to make the run. On modern cars the harness is plenty long enough to mount switches in the console with no modification, so if you found a way to mount them near your seat you'd be set. The relay portion is tricky to hide on my Cobra, usually I would mount it under the seat. I just have it wrapped in black felt and hot glued to the carpet behind the seat.
They are warm in a couple of minutes, hot in about 15 and at that point I usually turn them to low. I drove from Austin to El Paso this Christmas and they were great when the sun went down in the desert.
