Old 01-28-2016, 10:27 AM
Igofastr's Avatar
Igofastr Igofastr is offline
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Tim,
I'd have to disagree. It should work fine on an oil pan, though the pan would be somewhat difficult to remove.
I use this product extensively to seal case halves when I build Porsche motors. One advantage is that it never truly hardens, so it has some give when the two parts move slightly. Additionally, it does a pretty good job with filling minor imperfections in the mating surfaces. Obviously, extended exposure to oil is not a problem.
You can use it without a gasket if the surfaces are good. I also use it with paper gaskets on things like the oil pump cover on 356/912 motors.
Like I said, it seals pretty well, but wont separate as easily as RTV.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
