User Rick Lake suggested I use that stuff generously to glue the gaskets to the windage tray just as you describe and it works. I then use the Motorcraft TA-31 grey RTV sealant for the tray to block and pan to tray. It is the production line sealant for Ford's Diesel engines and gives a little longer setup time than the Right Stuff. Once I started doing it this way....no more leaks. I would not glue all surfaces with that aviation stuff though, it's very tough to get apart.
Jim
