Old 02-02-2016, 06:44 PM
Dusty Mills Dusty Mills is offline
Registered User
I haven't used the Griot's wax remover but as far as retail products go they have a strong following. So if this is wax in a trunk seal channel or something like that, and the paint is rough and not wet sanded, I use a wax and grease remover like 3M 08984, or Blackfire spray cleaner. If it's wet sanding slurry, I use a green scrub kitchen sponge. It takes some work to get slurry off if it's really set in. You can always do a test spot with what you have.
