Old 02-03-2016, 08:09 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Looks good Clois. It may not look like it now, but you may want to make those panels removable.
Re the air bleed at the top of the radiator, I routed that to the top of my header tank with a restrictor using a small hole, prob in the order of .040-.060, otherwise a lot of coolant will pass through this, and you really only want air. Then out of the bottom of the header tank is another unrestricted line that goes to the suction side of the system for fill, the header tank being the highest point of the system. Of course you may be using it for something else....
