Old 02-03-2016, 10:30 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
The header tank you are talking about is what I believe is called a degas tank from which the radiator and entire cooling system is filled. Looking at having one made because of lack of space of the traditional 2013-2016 Mustang GT factory OE. I have a call into Moroso to see if they have something with a vented screw on cap that measures 5" deep x 10" wide x 5" tall with a 11/16" main drain that goes into the fill tube at the thermostat and two 1/4" bleed tubes that will go to the Radiator and a bypass at the Thermostat.
If anyone has any experience with something like this please contact me as making a one off aluminium tank is turning out to be quite expensive..
Clois
"Let's roll"
"Be part of Something Good
