Old 02-04-2016, 04:30 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Depending on if you run a flat tappet cam or a roller cam you need to be concerned about ZDDP.
There is a product out there called "Cam Shield" which is full of ZDDP. But if your are already broken in and running fine, then the above should apply.
After putting my credit card down for a couple of cases of Gibbs, I may look at something else too.
