  #23 (permalink)
Old 02-09-2016, 03:03 PM
Dan Case's Avatar
Dan Case Dan Case is online now
Original Shelby Owner
Originally Posted by 427sharpe View Post
On the inboard connection, does the tank attach to the water pump inlet (heater outlet) connection alone, or to the bypass hose with a 'T' of some sort?
There was an aluminum tube between the water pump and expansion tank with rubber hoses and clamps for connections. There is a side connection at an angle for one heater hose in the aluminum tube. The other heater hose connects to a shut off valve mounted in the intake manifold. There is a small hose connection between the top of the expansion tank and top of radiator for vapors to escape to the expansion tank. The O.E. Ford thermostat bypass hose was not disturbed unless the car was fitted with some type optional intake and then I would expect on a different hose clamp on the thermostat housing end.
Dan Case
