Thread: Slave cylinder
Old 02-10-2016, 06:59 AM
Detroit Bill Detroit Bill is offline
Cobra Make, Engine: Superformance, Survival Motorsports aluminum FE 482
Default Alignment
I have better alignment than is depicted in that photo. I may create a new bracket if needed to correct it 100%. I picked up a used Dake bandsaw for work that should make it easier.
vertical bandsaws: Work-A-Matic SXC - Dake Machine Tools,*SXC
I have a massive critical project going on at work that will make the Cobra take a back seat for a while.
For projects:
I want to get the side pipes re-coated (and O2 bungs welded in).
Rear main seal fixed.
Hesitation/stumble after 6,000 RPM shifts fixed, I may let a tuner go after this.
Then I'll go after the alignment of the slave rod.
Bill
