Old 02-14-2016, 03:48 PM
SydneyChris SydneyChris is offline
Long time between updates.
It's been what the American Pickers would call 'smalls' for several months now, a bracket, fitting, wire, rivet, trim etc. The engine bay is nearly done, with the exception of a heat shield for the steering column and the washer bottle for the windscreen. Dash, about 70% there.. has been fabricated and fitted and removed for the moment awaiting the final covering. Pedal box is good, wiring is done up to the point of connection for the head and tail lights, have roughed up some inner guards for the rear wheels as well as fitted the splash guards for the fronts.
Biggest news has been the decision to 'move forward in a different direction' as opposed to going backwards, again.. !!
Ive taken the call before regretting it even more and dropped the floor height by 2" on both sides. Pics included of the floor paneling cut away and the main rail nicked ready for cutting. Will be replacing the 4" main rail with 6" x 2" RHS in 5mm wall. The stress calcs show its around 10% weaker than the original rail, but significantly stronger that scalloping the rail and adding a cover piece. Will also be adding a section from the side rail to the chassis upright at the rear of the passenger cell and a couple of uprights for side impact and torsional rigidity.
More pics to follow in a few weeks after the fab and welding is completed.
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
