Old 02-15-2016, 09:40 AM
lippy lippy is offline
Now that you are modifying your engine to be more "streetable," you might want to revisit the PCV issue.
May be worth considering.
How did you configure it on the BT intake? Since I don't have a vacuum port on my carb, this intake may make things easier, either by using the vacuum port on the intake itself, or by using a carb spacer with a vacuum fitting (I have more vertical room now).
Can you go PCV in the passenger side valve cover to the vacuum port on the intake, and then a breather with a tube into the air cleaner base? Is that right?
