Thread: Big Brakes
Old 02-16-2016, 12:24 PM
cycleguy55's Avatar
He's referring to the auto-valve bleeder screws. They have a one way valve in them to prevent air from getting back in the calipers. To use them you loosen them slightly, hook up a bleed hose to a can and then start pumping the brake pedal. When the pedal is pushed it forces fluid past the relief valve and as soon as the pedal is released the valve shuts - so you can pump all you want as long as fluid is in the reservoir of the MC. You don't need pressure or vacuum bleeder pumps.
They are how I finally got my ERA bleed out. But I thought back in the early part of your thread that you had these on your calipers ???
Yes - you can see the Russell ones here: Aftermarket Brake Kit Application Guide - Speed Bleeders - Russell Performance Products
They're widely available in parts stores, speed shops, etc. and come in a variety of sizes to replace bleed screws in OEM and after-market calipers. For Wilwoods you only need a pair for each caliper to replace the upper bleed screws - you can leave the lower bleed screws in place as you'll never use them anyway.
BTW, my rear lines were pretty much completely dry when I bled them, and I was astounded how many pumps it took of the brake pedal before I got anything out. The key message is it may take a lot longer than you think before you get all the air out. Brake fluid is relatively cheap - don't be afraid to waste some, and always start with the wheel furthest from the MC and work closer as you go (RR, LR, RF, LF - for LH drive cars).
Brian
