Old 02-17-2016, 09:56 PM
Wazza's Avatar
Wazza Wazza is offline
Hi Guye,
I'd say you will be needing the info that relates to the AP set up, so I've dropped in the following info directly from the current owners manual.
Track ‐ (15” Street Tyres)
For 15” tyres such as Mickey Thompson Sportsman S/T we recommend a starting cold
temperature of 35 psi, but re‐check immediately once they are hot.
Hot pressures should be 40 psi as a baseline.
Adjust from there to suit.
Shock Firmness Adjustment ‐ Track
We recommend initial settings of 12 on the front and 9 on the rear.
Adjust to suit.
I'll actually send you those pages...there's a fair bit of info on all of the various tyre size choices/street use/track use etc., but the bit I've posted above should give you the info for what you are doing and with the tyres you have.
Warren.
