Old 02-21-2016, 02:06 PM
twin turbo twin turbo is offline
Cobra Make, Engine: FFR
Gearing, tires, suspension optimization, air temps, road conditions, and rolling into the throttle vs punching it will determine where your traction (or lack of it) occurs. With my previous engine and transmission, I consistently fully hooked in 1st gear (Gforce 5 speed with 3.08 rearend gears, Nitto 555R 315/17 tires), as long as I rolled into full throttle with 420 rwhp (Mustang dyno). It felt good in 1st, but 2nd gear onwards was lacking for me. I just don't drive around much in 1st gear.
Nowadays, I typically drive with 550-600 rwhp and "usually" hook up from 2nd gear onward when the temps are 70 degrees and above, but have changed my set up to a full manual auto trans, 2.73 rear gears, and stickier Nitto NTO5R tires. Cold air temps, I can't hook up 2nd at all, even at 500 rwhp.
