Old 02-22-2016, 10:20 PM
MAStuart MAStuart is offline
Hi Larry I want to use the same calipers that the original Daytona coupes used . At one time you could get repos from Cobraracing. I think they used big 2 piston aluminum calipers. I am not sure what series they call them . Tried to get info from BG developments but got no replies. I think they called them race brakes as opposed to street iron calipers. I need to get master cylinders to mount on my pedal box so I can weld the box and mounting tubes in my chassis. On a coupe there is a tube that run from an outrigger down low up to the middle of the upper cowl tube. this tube runs close to one of the master cylinders. The pedal box has to be positioned right so the MC clears the tube.
Mark
