Old 05-08-2002, 12:36 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Hi, I used the painless 12 ckt wiring kit,the fuse block end is pre terminated. The wire is of higher quality and size so you don't need a light relay unless you're putting in high power driving lights. The ignition will need an 'on' toggle switch and a push button starter button wired to where the start would've been on a key switch. To make things easier I wired all the return ground ckts to a common copper block under the dash,that way you know where they are in a fiberglass car.
Good luck,
Perry.
