Old 03-01-2016, 06:32 AM
66gtk 66gtk is offline
Originally Posted by strictlypersonl View Post
The operative question is the bolt circle and backspacing. The ERA uses a 4.75" pattern. Backspacing is listed here:
Wheel size table
Are you referring to the bolt pattern of the wheels or the ERA hub? I think the trigo type adapters will work with either a 4.5 or 4.75 hub, or am I totally wrong? In any event, I'll keep researching. I'm looking to possibly replace a current wheel/tire set on a 2004 ERA from 17s to 15s. I'm told the 17" knockoffs currently on there are from PS engineering using the lug/pin adapter. I've located a set of 15s from a newer SPF and am wondering if they will work with my current adapters.
Troy
