Old 03-01-2016, 04:33 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Actually the fact that the carbs are canted at an angle does not really matter as far as the linkage goes, the linkage just needs to make the movement from idle to full throttle. Here is the linkage I fabricated starting with the same parts you used.
