Old 03-03-2016, 11:57 AM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Bob: I agree. I bought my set up used, and it came with a straight cut manifold. I had it milled for 10deg and the linkage no longer worked. Traced it down to the L & R throttle arms were going through different arcs at different times. I made a temporary fix by shortening one throttle arm and it all worked ok, but I plan on going to a center bellcrank when I can find one. System has been replaced with a 4 barrel set-up due to weber manifold sealing problem. (actually a head problem) on one side. Will be pulling engine for that and oil leaks, webers go back on when engine goes back in.
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
