Old 03-03-2016, 01:14 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Hmmm, the carbs are canted on our installation, the linkage setup I fabricated works perfectly. Paying attention to shaft angles really is important to linkage operating performance. One thing that you did not mention that you use is a level, some angles will change with movement but if the initial angles are wrong to begin with you are fighting a losing battle. Quality hardware is also essential.
