Originally Posted by Bernica
Not saying you are wrong, but I have seen Hi-Perf engines that wiped the cam within the first couple of hours and the reason in both cases was using the wrong break-in oil ( synthetic). I am sure that if Ford ran it, they used what was appropriate for run-in.
Not an issue with the Coyote. True for solid lifter cam, you need ZDDP but roller cam motors don't. Ford knows what works and these come with
synthetic from the get go. No worries on break in or down the road. As said, this is no longer the sixties. A friends Boss 302 race car wiped a cam at Watkins in less than 20 miles. He replaced the solid with a roller lifter and gained power as well as no issues with oiling.
