Old 03-04-2016, 04:48 PM
olddog olddog is offline
Originally Posted by Springbok View Post
Will they be able to cut and weld even if the pipes are ceramic coated?
No. Have to grind the ceramic off to weld. Then you can use some ceramic paint to touch it up, but it will show.
If you are picky enough to worry about the gap difference from side to side, you are not going to like the look after cutting and welding on ceramic.
