Old 03-04-2016, 07:25 PM
Springbok Springbok is offline
Cobra Make, Engine: 1965 Cobra made by Pacific Roadsters. 351 Windsor Crate Motor, 5 Speed Tremec Transmission
Originally Posted by olddog View Post
No. Have to grind the ceramic off to weld. Then you can use some ceramic paint to touch it up, but it will show.
If you are picky enough to worry about the gap difference from side to side, you are not going to like the look after cutting and welding on ceramic.
Its a pretty noticeable gap in my opinion, but you are right, I probably wouldn't be stoked on the touch up since the car is just as clean under as it is on top.
If I just get a new header and get it aligned properly, I can send that out to get coated again right?
