Thread: Have to go LPG?
Old 03-06-2016, 04:31 AM
just dreamin just dreamin is offline
Cobra Make, Engine: v10 ford
Its a can of worms, that subject. Im in SA and my advice may not be worth a bumper in NSW, but here, if you were to run injection and a factory computer your engineer would do an idle sniffer test and you could pass if you have some good cats installed.
But if you need an IM240 test your car goes on a dyno and exhaust gasses are measured. The pass mark is not a high as new cars and many have had their car tuned to get the reqd readings. That depends on what type of ECU you have.
Lpg gas fitting is not emissions free and they could require you to have a 240 test anyway . Your engineer should be giving you all the requirements and regulations that he has to sign off on.
