Old 03-06-2016, 04:08 AM
DanEC's Avatar
DanEC DanEC is offline
I assume your question is due to the body being off of the frame currently. Storing the body in place on the fame would be the best solution.
If that isn't possible, rig up a good wooden buck to support it and so that it's weight is well distributed. Point loads on fiberglass will imprint into the surface after time so cross beams, contoured to the body shape in front of the trunk opening and under the fender bulges further back are a good idea. Also, behind the hood opening and in front of the hood opening. Four points of support along the length of the body, tied to a couple heavy wooden frame rails, running front to rear should protect the body from warping and imprinting. Some weathering of the body is actually good to help stabilize it before painting - but I agree with others that I would prefer to keep it out of the weather and sun.
ERA 782 Running
