Old 03-07-2016, 04:23 AM
ASO544's Avatar
ASO544 ASO544 is offline
Originally Posted by jacobsed View Post
Excellent tips! Did you do anything with the landscape of the tire before applying the letters? Sand down ridges or anything?
I used a razor blade to remove any raised areas but a palm sander might have been the smarter choice. Prep wise you really need to clean and de-grease the tires....especially if not new. I then used acetone and a green brillo pad to remove any hidden oil or grime and it slightly scuffed the application area. I then followed the the instructions by using alcohol to clean the application area and rear of the letter prior to putting on the glue before gluing it down. I recommend using a heat gun or hair dryer to evaporate the alcohol on the letter and tire completely.
