Thread: 460 usability?
  #77 (permalink)
Old 03-09-2016, 03:46 AM
mdross1's Avatar
mdross1 mdross1 is offline
Originally Posted by Bentheroofer View Post
Aloha, I'm fighting an overheating problem right now with my 460BB Hunter Cobra. I'm baffled. I replaced the fan with twins, put in a 160degree thermostat. Everything else seems fine. Ii am curious, what do you mean by a fuel delivery problem. Thanks, in advance. Ben
The 180 degree thermostat is a must make sure all the air that flows through the nose has to flow through the radiator. Look at a Cobra that has the engine oil cooler with that baffling all air has to go through the rad.
Getting all the air purged out is also a must, I added a brass purge valve to the thermostat neck. My car runs approx. 190 degrees all the time in all situations. Stop and go traffic it will sneak up slightly. Finally are you certain your radiator has the capacity to cool the 460?
