Old 03-09-2016, 01:21 PM
patrickt patrickt is offline
Originally Posted by lippy View Post
Phil,
I recently pulled the heads off my car (ERA 797) with the engine installed. It was no problem, likely because I have studs that can be removed with the heads on the block, so the heads can then be removed. Do you not have studs? If not, I recommend you get the ARP head studs. They will make this work much, much easier in the future.
Note that his car is before the "big change" that took place with car #731. Now I'm just guessing, but it could be that pesky footbox is in the way and that got modified with the 731 and up cars.
