Old 03-09-2016, 02:04 PM
bobcowan's Avatar
bobcowan bobcowan is offline
You're not racing, and not putting extended miles on your filter. The Purolater Pro- (not the standard Purolater), or the Motorcraft filter will be perfectly fine. Both are inexpensive and easy to come by. No need to over think this.
I would never use a filter that does not have a bypass valve. The valve is a safety feature that allows oil to flow should the filter become clogged. If there's no valve, if the filter should become clogged the oil will almost stop flowing.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
