Old 03-10-2016, 06:53 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Hi Spook,
Looks good. Interested to know more about your diff cooler setup. I have the same pump for mine and am currently working on the plumbing.
what size lines are you running. I went with AN#8 and I'm hoping they are big enough for the thick oil
What kind of filter are you running? Wondering what mesh size and whether it's before the pump or after it?
Have you got a check valve in line to stop the oil draining back from the pump? I've mounted my pump down lower than the diff so haven't bothered with a check valve.
For the oil return to the diff does it just drain straight back in or is it directed to the crown wheel or center? I'm thinking about adding a tube to squirt the oil directly on the LSD center. (Hydratraks can generate a lot of heat)
Mike Murphy
Melbourne Australia
