Old 03-10-2016, 11:28 AM
blykins blykins is offline
Originally Posted by Large Arbor View Post
Brent,
Thanks and I did what you suggested and the response was Felpro did not make them in that size and his experience was good with Cometic. I also did not mean to be flippant, it just makes me nervous to move away from what the builder recommends, I certainly have seen your work and do respect your opinion.
Pat,
The owner dropped the engine in.
I was just curious what others are using and what has worked for them.
Phil
Didn't the builder use copper before?
I use that Felpro on every Pond block that I use. No issues with the larger bore. If you use the Cometics, I would at least try and spray them with Hylomar. Aluminum moves around so much (decks grow past sleeves) and you want the gaskets to do their best to seal.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
