Old 03-10-2016, 01:40 PM
Phill Pollard Phill Pollard is offline
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
Originally Posted by Dangerous Doug View Post
I saw only a marginal increase in the running lights with the reflector. I went to test the brake light difference but found I didn't have brake lights. This may be a brake light switch failure, so I plan to fix that in the coming days. I'll post some before/after pictures of the brake lights once I get them working again---that is where I would expect to see a visible difference.
I also plan to upgrade my bulbs to the Eiko part Bob had recommended to me a while back. I used them before and they were much brighter than the standard 1157LL's, but they burnt out when my voltage regulator failed.
DD
Easy enough to make a direct comparison;
Put the reflector on one light and not the other. Go into a darkened garage and turn the lights on. You should be able to compare them apples to apples.
A digital camera will probably be able to pick up the difference, at least in a darkened garage. I'm not so sure about in the light of day though.
Good idea DD,
Phill
