Old 03-11-2016, 08:28 PM
400TT's Avatar
400TT 400TT is offline
The engine offset to passenger side is around 25 to 30mm depending on drivetrain fitted.
Offsetting the drivetrain gives us 3 main advantages, which you guys have already touched on:
  • More cockpit space for the driver, especially footbox width for drivers feet.
  • Better cross-weight balance
  • Reduces torque effect of engine on handing
Originally Posted by Jaydee View Post
With the offset it would also add weight to the left as the torque effect wants to lift the left side up. Does that mean in a left hand drive the offset is also on the left.
JD
JD, very astute of you. Offsetting the drivetrain works best on RHD, you just can't get all the benefits with LHD.
www.absolutepace.com
