Thread: trailer build
  #28 (permalink)
Old 03-12-2016, 03:45 AM
deano59 deano59 is offline
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
Originally Posted by Tenrocca View Post
Dont want to keep hijacking this thread but Deano started it
Bought a kit from Bermuda Pools pools but had a local guy install. Reckon it could be done yourself - but go and watch one being put in first. It would be hard to get right the first time. Did the concrete beam and coping myself which is pretty easy to do - make sure you use a vibrator to get the concrete in under the lip.
Jaydee, in Sydney at least a pool tends to add real value to a house and are much easier to maintain with auto chlorinators and fresh water systems then in the past. I think there was a time when a lot of pools were being filled in but that doesnt happen much anymore.
Anyway - back to Deanos terrific looking trailer..
we are using a fresh water sytem called a enviro swim no chlorine or salt used the water passes over a copper and a silver electrode the silver sanitises the water and the copper stops algy .only need to run the pump for 3 to 4 hrs a day in summer less in winter they tell me only thing you need to check and keep right is the ph levels . i tend to itch a real lot after been in a salt pool or a chlorine pool hence going with the enviroswim unit .
went down to the workshop today and started cladding the rear door/ramp should have that finished tomorrow all going well.
cheers deano
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
