Old 03-17-2016, 10:38 PM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Originally Posted by stephen low View Post
Guys
... I want to progress my soft top and so will need to finish off the frames already made by Marty...
I'm not sure what information will assist as I had to make the frames and as such mine might be a completely different design concept from those you have.
I folded sheet aluminium to suit Bailey channel I purchased from a rubber supplier to suit 6mm thick perspex.
I either cut or notched the frame sections and then welded them to the shape of the window. I made the bottom section detachable to facilitate installation and removal of the perspex.
The most difficult task was creating the mounting points to the door in the limited space available. It was exhaustive trial and error.
It all seemed to come together okay.
