Old 03-18-2016, 03:56 AM
mdross1's Avatar
mdross1 mdross1 is offline
I used Wilwoods all around with a better than 48 front 52 rear bias the rear brakes certainly added a lot once the proportioning valve was properly adjusted.
It also took a couple tries to find the right pad compound now can very easily scrub off speed with the right pedal feel. It is all about dialing your ride in to your comfort level brakes certainly are an important part of owning one of these incredible muscle cars.
Another just as important part is having the suspension scaled when running coilovers on all four corners especially if you plan on pushing the car to near it's limits. Also a properly scaled suspension greatly improves braking control.
